Hi guys, I'm soon to be building my first system, I want it to be Micro atx so I can move it around easily (moving to uni next year). My budget is ~£600. I'll be using it mainly for gaming, heavy duty photo processing+editing and general web/office use. Just a few things to note before i post the spec, firstly I live in Jersey, in the Channel Islands, so all prices are ex VAT (yay, more bang for buck!). Secondly I don't need any HDD's or optical drives, already got some scavenged from an old dell. This is the spec I've drawn up, what are your thoughts on it, am I doing anything wrong or could it be improved? I decided whilst the performance isn't as great as i5s I would go with AMD so I could spend more on the GPU and get a SSD to boot windows rapidly. Is that the best thing to do?
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard (£49.57)
AMD Phenom II X4 955 3.2GHz Black Edition Socket AM3 L2/L3 6MB (£92.76)
EVGA GeForce GTX 460 1024MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game (£117.99)
Iiyama ProLite E2208HDD 22" Widescreen LCD Monitor - Black
(£97.86)
Kingston SSDNow V-Series 30GB 2.5" SATA-II Solid State Hard Drive (SNV125-S2/30GB) (£47.99)
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel (OCZ3G1333LV4GK) (£47.99)
NZXT Vulcan Micro ATX Gaming Case - Black (£46.80)
OcUK Battle 450W Dual Rail High Efficiency Modular Power Supply (£34.88)
Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan - 3 pin (£9.35)
Akasa AK-184-L2B Amber Ultra Quiet 92mm Fan - 3 pin X2 (£11.98)
Lastly, I'd like to try my hand at overclocking,has anyone got any recommendations on cooling? I think it needs to be fairly compact due to size constraints.There seem to be an endless amount of aircoolers, and I'm not convinced that stretching to a corsair h50 is worth the performance gain or hassle of modding the case to make it fit.
any help is appreciated!
Dan
(£97.86)
Dan
