Hi all
Please could you help me, I would like to get the Corsair Obsidian 650d with the below items, my question is, do i need to use water cooling ( cpu and gpu blocks) and wil it all fit in the case, or could i just use the (Corsair Hydro H100 Extreme Performance Liquid CPU Cooler)
Second question, will this be a good build or should i change anything?
Corsair Obsidian 650D
Intel Core i7-2600K 3.40GHz (I want to over clock)
Gigabyte G1 Sniper 2 Intel Z68
Corsair Vengeance 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive ( 1 for windows and another for my games)
Asus GeForce GTX 590 612MHz 3GB GDDR5 PCI-Express 2.0 DVI miniDP (I might get another one at a later date)
Corsair Professional Series AX850 High Performance 850W Modular '80 Plus Gold' Power Supply
Thank you
Steve
Thank you
Steve
so it may be better me getting gtx 580 3gb insted of the 590's as i am only going to use this to play games
