- 5 Mar 2008
Going to have a go at my first build and looking for some advice on components. Going to be used mainly for gaming and surfing the net.
Plan to use the antec 900 case, pioneer DVR-212 DVD RW, samsung spinpoint 160GB hard drive, both SATA. Was also planning on either the Antec TruePower Trio 650W PSU or Corsair TX 650W ATX2.2 SLi Compliant PSU
My main concern is choosing the correct processor,ram and mobo combo.
Was thinking of
mob:-http://www.overclockers.co.uk/showproduct.php?prodid=MB-243-AS&groupid=701&catid=5&subcat=913
processor:-http://www.overclockers.co.uk/showproduct.php?prodid=CP-192-IN&groupid=701&catid=6&subcat=793
or
http://www.overclockers.co.uk/showproduct.php?prodid=CP-210-IN&groupid=701&catid=6&subcat=793
I'm really unsure what is the best option, do i go for a core 2 duo or a core 2 quad. I plan to do a bit of overclocking but don't want to push to the limit and will use an arctic cooling freezer 7 pro cooler. Any advice here is welcome on these or other options, not looking to go more than £200 for a processor.
RAM:- Again not realy sure about the best option but looking at this
http://www.overclockers.co.uk/showproduct.php?prodid=MY-124-CS&groupid=701&catid=8&subcat=813.
I plan to still run XP as i'm not convinced about vista yet so 2GB should be enough.
Not chose a graphic card yet, will wait till i'm going to order the above and see what cards are around at that time, it will be Nvidia though.
Any comments/help on the above is much appreciated.
thanks
glen
Was thinking of
or
thanks
glen
