Hi, I bought my first pre-built 10 years ago, and have since transferred the components to a larger case, upgraded the cooling, RAM, GPU, PSU, PCI USB3 ports, and added/swapped various drives including an SSD.
The PC is getting a bit slow these days and so I'm wondering if it's feasible to overhaul it using my existing case, PSU, HDDs, and cooling setup which are:
- NZXT Phantom 410 Black - Mid Tower Gaming PC Case, Upto ATX CA-PH410-B1
- Corsair Gaming Series 2013 Edition GS 700W ATX/EPS 80 PLUS Bronze Power Supply Unit
- Corsair (CW-9060021-WW) Hydro Series H100i GTX 240mm Extreme Performance All-In-One Liquid CPU Cooler
- A combination of 6 x Corsair Air Series SP/AF120&140 fans.
- 5 x HDDs
- ASUS ROG STRIX Z490-E GAMING, Intel Z490, S 1200, DDR4, SATA3, Dual M.2, SLi/CrossFire, 2.5GbE/ax Wifi, USB 3.2, ATX
- Intel Core i7 10700K, S 1200, Comet Lake, 8 Cores, 16 Threads, 3.8GHz, 5.1GHz Turbo, 16MB Cache, 125W, Retail
- Gigabyte GeForce RTX 2080 SUPER WINDFORCE OC 8GB GDDR6 Ray-Tracing Graphics Card, 3072 Core, 1650MHz GPU, 1830MHz Boost
- 32GB (2x16GB) Corsair DDR4 Vengeance LPX Black, PC4-28800 (3600), Non-ECC Unbuffered, CAS 18-22-22-42, 1.35V
- 1TB Samsung 970 EVO Plus, M.2 (2280) PCIe 3.0 (x4), NVMe SSD, MLC V-NAND, 3500MB/s Read, 3300MB/s Write, 600k/550k IOPS
