Hi peeps,
Thinking of putting in water cooling for the first time and considering one of the OcUK kits - the V8 Watercooling Kit 240.
It will go in an Antec 1200 v3 with a Gigabyte EX58-UD5 & an i7 920 2.67 @4.00GHz
I currently get idle temps around 50C going up to about 70C on load but I find all the fans a bit noisy sometimes - 3 front 120mm (in), 1 top 200mm (out) & 2 rear 120mm (in), so was thinking it might be time to go water cooling.
Anyway, any advice on the proposed kit or other options I could/should consider?
Thanks
Thanks
