Hi there,
1st things 1st , Here is my pc spec to be that is :-
Intel Q6600 2.4 (want to clock to 3.6)
Asus P5K3 Deluxe
4GB Crucial Ballistix 1066
ATI 3870 HD 512mb
620w Corsair PSU
now here comes my problem
I was going to buy the Thermaltake Kandalf LCS VD4000BWS as ive allways wanted to water cool but never done it as yet. but a shop (no names mentioned) said for get it the case is rubbish and a air cooled cpu cooler would be cheeper and better at cooling!!!
so has anyone got this case?
Or should i buy single bits
i have priced up the following but its very expensive about £253
DangerDen ClearFlex60 1/2" Tubing - 3m
Swiftech Laing D5 Vario MCP655 12 VDC Pump
XSPC Full Cover 3870 VGA Block
Alphacool NexXxos Xtreme II Rev2 Double Radiator
Feser One UV Reactive Coolant 2 Litre
EK Supreme Acetal CPU Water Block
EK 1/2" Hose fitting X8
XSPC Laing DDC Pump Top Reservoir
please some one help what would you do?
Thanks
Asus P5K3 Deluxe
ATI 3870 HD 512mb
620w Corsair PSU
Thanks
