- 9 Sep 2008
Well basically I'm looking to watercool my GTX 460 SLI so that I can overclock them as much as possible.
ATM, I'm not limited by temps, so no point cooling my 2500k.
I'm deciding whether to fit a 240 or 360 rad in.
Will a 240 rad be enough? a 360 rad would sacrifice all of my DVD drive slots and my hdd cage.
I'm hoping a 240 rad will do, I've bought a Laing DDC Ultra 18W pump fitted with XSPC resivor top. just wondering a couple things, I've got a while until I will build this, so I want to get everything right.
Here's what I'm thinking atm:
ThermoChill PA120.2 - 240 Radiator (24.5mm)
£47.82 £47.82
2X EK Water Blocks EK-FC460 GTX GS/SONIC - Acetal + Nickel
£56.64 £113.28
Primochill tubing PrimoFlex Pro 19/13 (1/2\"ID) UV-active green - 1m
£5.28 £10.56
Yate Loon 120mm D12SL-12 LED Green - 1350 RPM
£4.39 £8.78
Delivery £7.99
Subtotal £188.43
VAT@20% £37.69
Total £226.12
First off, which rad's are best?
Haven't decided about barbs etc yet. But advice would be really appreciated.
Also deciding over colours still, I want something UV reactive as I've got quite a few UV cathodes and LEDs. I was thinking RED, but I know it doesn't look great under UV. So I might just go with the usual Green. Decided on green tubing and normal colourless coolant. Also, for the coolant I'm thinking of getting some Feser Aqua (is this stuff the best?)
£47.82 £47.82
£56.64 £113.28
£5.28 £10.56
£4.39 £8.78
Delivery £7.99
Subtotal £188.43
VAT@20% £37.69
Total £226.12
