1st World Problem / Dilemma...
3 Aug 2003
Plymouth, UK
....and looking for some advice / sanity checks before I do anything.
A few weeks back I upgraded my PC to an i7 4790K and a Gigabyte Z97Z-SLi board.
Feeling clever with myself, I decided that I would use the m2 slot and bought a Samsung 251 module......only to find out I am a numpty of the 1st order and the board I have only runs it at 10 GB, instead of the 32 it can run at.
So....I find myself in a quandary with as I see it, 3 possible solutions
1 - Stay 'as is' and live in the knowledge that the m2 is not running as fast as it should.
2 - Get a Z97 board that supports Ultra m2 and slap the old one on MM, keeping current gfx card (xfire 7970/280x under water), but knowing that I may be running the cards slower than I possible can due to limited PCi lanes
3 - Keep my current mobo and get a single clot gfx solution and one of the Asus adapters and put m2 card into that in a spare pci-e slot.
If 3 (which is what I am kind of leaning too) then what gfx card to get? Stick with red and look at Fury and Fury-X, or look at green and the 980 and 980ti.
Games wise am currently playing FO4, JC3 and Elite Dangerous, but looking to add in some Star Citizen and EVE too. Currenlty have 3 montior eyefinity too, so am looking to keep the three screen setup....
As said, 1st world issues, but what would others do?
Option 4: Sell everything and start fresh with X99 for the extra PCI-e lanes...
Okay maybe a little overkill. But personally I'd go option 1. Will you notice a day to day difference with 10gb vs 32gb?
Option 4 would be good...but would need a butt load of cash as will need to get 32 GB of DDR4 as use a RAM disk for some astro photography image processing swap files and that would be a killer......
Personally I'd test it and then decide
step 1 benchmark system without m2 drive to see what the gpu's perform like
step 2 benchmark with the m2 in and see how the gpu's perform
You likely wouldn't notice a real difference in day to day use anyways
I was totally underwhelmed by M2 tbh. In the real world i noticed very little if any difference. The difference between HDD and SSD was MASSIVE the jump from Sata to M2 was Technically big real life.... very little imo. option 1
Twice as fast as SATA or half the speed of full M2.
Hmmm, I suppose it all depends on whether you're a glass half full or half empty kind of person.
