The thing is I was having stability issues at 2t but 1t APPEARS to have fixed it. Is this possible? I also changed the mem voltage to 2.8 from 2.7 but the mem is only at 192.8 (fsb 245x11), the vcore is at auto (1.36).
I had stabilty probs recently till i upped my ram volts to its max rated 2.8 .Try and get your ram to its max oc,1t and an oc will make it even faster.
Use this handy tool to get an oc nearest your highest ram oc http://www.radeonx.com/dump/a64_oc_calculator_v0.2.zip.
From what i`ve read some ram doesnt like going over 250 fsb at 1t so you could try a low level oc to start out.Oh and remember to give your cpu more volts (about 1.4) to start off with.
