1x 22" or 2x19"
30 Oct 2002
Swansea / Ammanford
Hi
I'm in work at the mo
I got the choice of having:
1x 22" Dell Monitor
or
2x 19" Value TFTs
I know the 22" will have a lot of desktop space, but obviously the 2x 19" will have more overall.
If you had the choice, what would you go for?
Hi
1x 22" Dell Monitor
or
2x 19" Value TFTs
Is this actually for use just at work? If it was me and work offered me this choice i'd go with 2X19"
I would go for the 22" if its for games, videos and just normal pc use plus if its widescreen thats a bonus I find widescreen a lot better for nearly everything.
I would go for a dual screen setup if you are going to have lots and lots of windows open. I had a dual screen setup and honestly I barley used the second screen. The only things open were MSN, Itunes and sometimes VLC if I wanted to watch a video while browsing the web.
hmmm... thing is, i've had a single 19" for awhile now and the quality isnt that bad.
A 22" WS is quite tempting though, however the res is only 16xx by 1050.
I currently have 11 windows open at the moment between a few different apps, ie, remote desktop and a messenger app.
Problem is, i'll be stuck with a 22" if i go for it and not like it... I may be able to skive a 19" as one will be spare to go along side the 22"...
Thats if i get lucky mind! :p
I run 4x 19" at work and 2 screens at home. I always end up using a second screen and think it's much better than a single larger screen. Being able to maximise multiple apps at once just makes you much more efficient.
