1x(2x4Gb) or 2x(1x4Gb)
Yes, they're matched pairs which means they come from the same batch/chips - so should run together without any hiccups.
It's advisable to buy dual kits so you don't run into compatibility problems. (although buying unmatched modules even different brands isn't the problem it used to be - as long as the spec is the same/similar).
Basically, you're eliminating a possibe problem buying matched pairs...
