1x 6950 or 2x 560ti ?
7 Feb 2011
Holywood, County Down
So final part of my upgrade is upon me and the question is
1x MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB @ £229
or
2x Asus GeForce GTX 560Ti DirectCU II TOP 1024MB @ £179ea (1 now SLI in a couple of months)
I'm confused about the whole 1Gb v 2Gb of VRAM.
I play at 1920x1200 and trying to sort myself out for the likes of D3, Skyrim and GW2. I wont be playing BF3 which is where a lot of the debate around VRAM seems to have started.
Finally its going in a i5 2500k on a P8P67 Pro system
Any thoughts appreciated.
Ta in Advance
I always recommend single cards, so 6950, though that being said a 570 can be had for £250 if thats in budget
Reason for single cards is
- less heat
- less noise
- no SLi/Xfire issues
- no micro stutter
- by the time you come to add a 2nd, its often better to sell current card and get a new single gpu again
The ATI is a bit faster than the 560 ti overall (but there's not a great deal in it). Either card should handle those games just fine at that res.
I doubt you'd need to crossfire/sli either - and multiple cards adds it's own set of problems.
I'd be tempted to get a 2GB card, particularly if you are thinking of modding Skyrim. (although remember, there's no mods yet!)
