1x120mm radiator ?
2 Jan 2010
Denmark
Need advice on 1x120mm radiator
Can you help me, with one of these 3 radiators I have to go?
1 - Black ICE Radiator GT Stealth 120 – lite
2 - EK Water Blocks EK-CoolStream RAD XT 120
3 - XSPC Rx120-D Single Radiator
Its for update my loop, I have one 3x120mm
Just wondering, that Laing DDC-Pump 12V DDC-1RT/Plus will be powerful enough for single CPU, GPU and 2 radiator loop ?
And any ideas how loop this components together ?
I would say the xspc is the best option out of those you may need upgrade your pump with an aftermarket top to maintain the flow rates with that loop as it will be fairly restrictive
Thanks, and can you be more specific with - you may need upgrade your pump with an aftermarket top ? I building water cooled rig first time, that why I asking probably to much..
My case is HAF 932 that mean, its I lot of space for upgrades, that why I was thinking add another radiator – probably its not necessarily and single radiator loop will do for single loop setup ? Right now I have EK Water Blocks CoolStream RAD XT 360 radiator.
