2.16Ghz MBP + 1080p .mkv
18 Oct 2002
Manchester
Hi I'm trying to play the latest Eve Online trailer it just will not play, keeps freezing/dropping frames. The audio plays fine.
I'm using VLC and have always had problems with files like these, is it 2Gb RAM causing the issue, in not having enough? or the 5400rpm HDD or is it simply a case of not enough procesor speed?
Only got Safari open and VLC.
Most defiantly not the hardware behind the dodgy playback, I'll hazard a guess at low HDD space or VLC not playing ball correctly or both. :confused:
