2 borked 2005 fpw's in a row
Caporegime
18 Oct 2002
Ireland
What are the odds of getting 2 monitors in a row with exactly the same problem? My first 2005fpw worked fine untill it developed a habit of refusing to display a signal untill i had disconnected and reconnected the dvi cable. This happened with both dvi and vga connections on 2 different pc's with THREE different graphics cards so a gimpy card is out of the question.
Now this bloody monitors going the same way, had to mess around for about 20 minutes tonight to get the damn thing to display a signal. Thing is though its a totally intermittent problem, some days it'll be fine, then i'll turn the pc off for an hour or so, come back up and then it'll start its antics. :(
