2 choices, advice please.
24 Nov 2007
Leeds
blond or brunette? :) I think the aqua looks nicer IMO, but the other has seems to be well liked, looking at the reviews. The main difference appears to be the higher contrast ratio for the aqua. If you think its worth paying extra for then go for it! :) There might be some threads in this section of the forum relating to these monitors, might be worth checking them out (if there are any!). Hope that helps ;)
Thanks,
There's not a lot around on 20" monitors, especially the aqua.
Does no one buy 20"? Is it all 22" and 24" these days?
