2 GFX Cards in Asus P5KC Possible???
18 Apr 2008
Bristol
Does anybody know if it is possible to install and run a second graphics card on an Asus P5KC.
I currently have 1 9800GTX. My system is mainly for running Flight Simx. At the momeant i have 4 monitors. 1 is connected to a dvi slot on the 9800 GTX and goes to a matrox triple head to go that spans the cockpit across 3 screens. The other monitor is connected to the 2nd DVI on the 9800 and runs a program called flight sim commander which gives me mapping/position information.
Because of running this other program i have to run flight sim in windowed mode which detracts from performance.
What i would like to do is use the 9800 to run flight sim in full screen mode, and install a Nvidia 6600 (or similar) to run the 4th screen.
Any body know if this is possible???
Thanks in advance
Craig
no its a crossfire board according to several searches, little tip, type your mobo in google and look at the spec.
i think he knows he got crossfire board as he's not talking bout sliing up the 9800gtx with 6600 which is not possible to beging with plus what would be the point :P
in theory i think its possible tho not sure about reality, have a look in your manual (@work so cant look in my)
