2 GPUs & CPU in single loop doable with Therm 360 rad?
I had a pair of 7800GT's, CPU and NB in the same loop with a Alphacool Nexxos Extreme lll rad and that coped with it. It copes with my E8500 at 4.5Ghz, 4870 and NB still. A Thermochill should manage it.
Hmmm thanks for the replies. I really don't want to go dual loop as basically I can't be bothered to mod my TJ07 to take a 240 rad internally in the roof and also because money is very tight at the moment.
Anymore opinions/experience out there?
What sort of idle/load temps are you getting on your cpu and gpu in your current loop matey?
And can you remember what you were getting in your previous gpu/gpu/cpu loop?
My temps have always been stupidly low due to having the rad mounted in a box on the windowsill. :D
The hottest i have ever seen my cpu is 42 degrees and that was while running Orthos and Fur stability test at the same time. The 4870 is usually in the mid to high twenties although the warmer weather last week saw it reach 35 degree's. This was while gaming.
Can't remember what temps were like in the old SLI loop. That was quite a while ago with a 754 and then 939 rig. I have had several upgrades since then although i still have the same watercooling setup from 4 years ago. Minus 1 gpu block of course, but everything else is the same. :)
