2 hard drives
newbie question but
can i have 2 hard drives in my pc one with windows on it and the other with all my programs on it
By programs you mean applications or TV programs? Yeah but it would make more sense to have windows and your windows applications on the same HDD and then all the rest can go on the 2nd HDD
applications yes i have a small harddrive i woulod like to put windows on incase it crashes so all my apps are nice and safe on a separate hard drive
Yes. Windows would be installed on 1 of your Hard Drives. Then, when you go to install any application, theres usually a "Custom" or "Advanced" button during setup you can click.. this will then give you the option of where you want to save it...
By Default this location would be something like: C:\Program Files\My Program
You would change this to: D:\Program Files\My Program
*Where "D" is the letter of the drive. "Program Files" syntax optional.
