2 inputs to Dell 2407 problem
5 Jan 2005
Engerland :)
ok I have my dell 2407
connected to 2 dvi monitors.
thought I would use my PS3 on it as well via a hdmi to dvi cable.
soooooo
looking around I found a DVI splitter cable - easy I thought - use 1 from the ps3 to it and the other to the monitor.
When connecting the splitter cable to the monitor - then the pc to it it just enters power save mode!
thats without connecting the PS3
how come ?
I think that cable is for one source to two displays not the other way around. A DVI Switch is what you need, and I have one for the exact same reason as you and it works great :)
cant you connect your ps3 via the component input ?
ive got
pc --------- dvi
pc --------- vga
xbox360 --- component
and they all work fine :D
the lead can be had online for less than £7 :D
