2 into 1 stereo 3.5mm jacks?
  • Thread starter Thread starter itm
  • Start date Start date
Definately wouldnt recommend that, could damage the input on the speakers.
Are you using all the inputs on the interface? If not connect the PC to a spare input and just connect the interface to the speakers.
If thats not an option then search on the big river retailer for "Andifany CX400" and select the Musical Instruments & DJ department. Should be the first result. It's a 4 channel stero mixer for £17. Has phono inputs and outputs so you may need some additional cables but its passive so doesnt require power and will allow you to properly balance the two inputs.
