Hi all,
Quick question, my media centre pc died the other day and I had a static IP set on the NIC. I had a spare motherboard and CPU lying around, so I threw the HDD in that and everything came back up and was working fine except SABnzbd. After some looking around I noticed the static IP was missing and had gone back to DHCP, so I set the static IP again and after some messing around on my router, I managed to get the IP set again. The issue I have now is the NIC has 2 IP addresses. The static IP I set and an APIPA, it doesn't seem to be causing any issues with connectivity, but both IP can be pinged and respond and when I reboot the PC, it takes a minute to get the APIPA. Does anyone know how to get rid of the APIPA? I assume it's something to do with fact that the old mother board had a different branded NIC and it has a hidden device set somewhere holding some config...
Any suggestions would be much appreciated.
Cheers,
Locrieth
Cheers,
Locrieth
