2 Macs, 2 iPods/iPhones Sharing
18 Oct 2002
Just wondering how to do this....
Current setup is this:
MBP (my computer, the first Mac) has it's iTunes setup to reference the music located on a shared drive.
iMac (my wifes machine). This machine has stores the music files (the music folder is what is shared).
I added music to my iPhones library using the File -> Add to Library option.
Likewise, we did the same with my wifes account on her machine.
My iTunes is setup with my UK iTunes account.
Wifes iTunes is setup with her Japanese iTunes account.
We've authorised the DRM'd music as appropriate from each other's iTunes purchases.
My iPod Touch connects to my machine, and I copy ALL the music to that one.
My wife is probably getting a iPhone 3G soon, so we'll be wanting to sync music onto that as well.
So can I do something like this.
On my MBP, I have my music files only. I add them to my library as before.
On my wifes iMac, she has her music files only, and adds them to her own library.
We then both use the "Share my library on local network" option for our music. That means I can play back her music, and she can do the same with mine on our own machines.
Now this is the question. If she then plugs her new iPhone into her machine, will it synchronize both her own music plus the stuff I shared with her via iTunes. Likewise, when I connect my iPod, will it sync both my own local music, plus the stuff shared via wife's iTunes setup.
Hope that's clear?
It will only sync what you tell it.
In the "Music" tab within iTunes, just pick the playlists you want to sync.
Obviously, if you've gotten songs from her library in your playlist it will attempt to sync them.
FYI: If you have a machine that's always-on you can create aliases (e.g. shortcuts) to the files, and iTunes will treat them as if you have the files on your machine. The problem lies if the machine dies, or someone turns it off; you won't be able to play them.
