- 30 Dec 2009
- Wigan Lancs
If i was to use a 2 monitor set up do the monitors have to be set to the same resolution.
What i plan to do is use them for MS FSX and use one for cockpit view and the other for certain instruments etc.
So can one use 1920x1200 and the other at 1680x1050 as these are the maximum native resolution for each respectively.
Thanks.
Thanks.
