I'm probably gonna explain this rubbish, but bear with me...
At work, I use 2 monitor, a 15" and a 17". The ideal world would say that I should use 2 17" but this is irrelevant at the moment.
I'm thinking of buying the new VX2235 22" Viewsonic and at present I have a Viewsonic 912 19".
The resolution of the 912 is set to 1280x1024 and the max resolution of the 2235 is 1680x1050.
On my works monitors, because the resolutions are different, if I move my mouse from the 15" to the 17" it goes across no probs, but moving from the 17" to the 15" I have to ensure that the pointer is less than the maximum resolution of the 15" monitor otherwise it just 'sticks' to the monitor side.
With me so far?
So...
If I purchased the VX2235, whilst I appreciate there's a difference of 26 pixels vertically, can I set the resolution of the VX2235 to be x-amount by 1024?
Or would it simply be a case of the 26pixels are soooo insignificant that I'm being too picky?
[size=+1][/size]
With me so far?
So...
[size=+1][/size]
I already have that setup as you can see in my sig
