2 monitors with different resolutions
25 Aug 2005
Derbyshire
Is it possible to have 2 different monitors connector to the same graphics card, one with sya 1280x1024 and the other 400x300 resolutions. Maybe also display seperate desktops? I have a mini screen that I would like to use (maybe just for winamp/ displaying if I have new emails). I'm thinking of modding it into my case. The first monitor is my normal one, plugged into DVI, the 2nd is plugged into my TV out (as it takes NTSC format). Any ideas? Cheers
May I ask how? When I plug the 2nd monitor in (via s-video) the only options I get is to split the screen, which gives a too high resolution for my rubbish little screen.
Thanks chaps, after bieng convinced by you that it's possible, I went on a settings hunt, and found it. And it looks pretty good. my card is an XFX 6600GT.
