2 monitors
5 Jan 2010
iv got 2 monitors 1 is 24" tothers 28" both are 1920x1200 (i think lol 1 MAY be 1920x1080) the card is a 5870 how woul;d i go about using both would i just set the res as 3840x1200 (or 1080)? do games support that? would it look better or really stupidly stretched?
You want see the same image stretched over two screens ?
If they are of different make/model etc they will never process at the same rate.
Still I can tell you how to do it bar its not really likely to provide any benefit :confused:
tahts my question will games have a nice wide angle or will it just stretch the hell out of a 1920x1200 source ie everybody looks massively obese?
A game will often only support native resolutions, the kind of hybrid version you describe I cannot think for one minute would be supported.
To connect two screens you would need to use two outputs from your card (I believe) unless the software supported it, you at best would end up with 2 identical screen images, give or take the processing lag of your different screens, not a panoramic view.
