First off, I would like to say I have built several computers in the past and I have a working understanding of doing so. The reason I am being even more hesitant is because the budget for my latest project is a bit bigger than normal.
I will try to detail out as clear as possible because I dont have the money to get this wrong
- I have been allocated a budget of £8000
- I will be responsible for buying constructing and testing 2 full systems.
- The systems will be used for 3D rendering/ animation & Game design.
- Minimum is dual monitors.
I have checked components over OCUK and can see that this is easily achievable but I would like to know what parts other people would select for this build.
Even though the budget is £8k it does not mean I have to spend every penny
Some things I have considered
* Dual 28" 4k monitors with 2 smaller monitors
* Nvidia 980GTX SLI
* CPU i7 (but which one)
* Ram (what would be best for this type of work?)
Thanks for your responses.
* Nvidia 980GTX SLI
