- 12 May 2011
- Southampton
It's not as erotic as it sounds!
Is there such a thing as a USB 'merger'? If a 'splitter' is something that allows you to connect multiple devices to one usb port, is there something that allows one device to be connected to multiple PCs? Duplicating the signal?
I have two PCs (one 'retro' XP PC and my normal one) and It would be good to not have to keep swapping the USB reciever between PCs if they could just share one usb 'cradle' that was plugged into both PCs. As they'd probably not be turned on at the same time.
