add to that the large amount of heat that would be generated from both machines in one case :-/Raikiri said:Not that I know of, if you wanted to do it in a standard sized case one mobo would have to be fitted BTX style (upside down) and the other the standard way plus you would have to use mATX boards. Not to mention fitting 2 PSUs and makuing space for PCI brackets all the way down the back of the case. And wiring the switch so it turns both on at once.
Once thats done you would have the problem of actually accessing the computers, I guess one would have to be mounted on the side panel somehow.
MyBoxLife said:Has anybody had a go at custom building 2 PC's in 1 case?
nikebee said:add to that the large amount of heat that would be generated from both machines in one case :-/
