Hello,
I'm planning on getting two Scythe mini kaze 60mm fans and would like to know for sure if these will work on a 3 pin fan controller as they only have 2 pin connections although they do have an adapter.
I know the 3rd connection is for the pulse reading, but just want to confirm before buying.
Will be using:
Lian Li PT-FN06B Fan controller
Scythe Mini Kaze SY602012L 60mm
Thanks
Will be using:
Thanks
