2 port hub/switch ??
6 Jan 2006
Newcastle
i need a 2 port hub / switch very small and tiny, as it will be used to fit into a compact space, and it cant be a splitter any idea peeps ?
If you're splitting a port into two you actually need 3 ports. One for each end device, one to uplink via crossover cable to the intermediary device.
3 port hubs/switches are hard to come by but 4 or 5 port ones are widely available and are often very compact. Around 15-20cm square by 2cm deep.
i found a 3 port switch which is what i needed i dont have a clue why i said 2 ..... but thanks anyways guys
its for some security cam stuff all of it needs to be compact and 4 is just overkill and way to big for the size i need
