- 23 Aug 2010
Question 1:
Just bought an Asus P8P67 LE mobo, and the manual isn't too clear on how the ram slots are paired.
Working away from the processor socket they are labelled
DIMM_A1
DIMM_A2
DIMM_B1
DIMM_B2
Just want to know whether i should install RAM in an alternating pattern, or in neighbouring slots for Dual Channel
I'd imagine the board is very similar to the higher end Asus P8P67 boards, so if you have one of them, let me know how yours is set up.
Question 2:
Installing power supply in case is proving problematic (Coolermaster Elite370)
The screw holes for the supply and the case aren't lining up as the supply is raised about 5mm too high. I believe its being caused by the far sides of the case feet, which protrude quite high into the case, in turn causing the supply to be raised up the crucial few mm.
Thought of maybe filing the top of the feet down a bit, but wanted to see what other people think.
Don't want to RMA it, being out in the Channel Islands would be more fuss and time than its worth
Thanks for your patience with a noob.
LR92
DIMM_A1
DIMM_A2
DIMM_B1
DIMM_B2
Question 2:
LR92
