This was a complete overkill rig that I just built but I had my reasons:
I had built more than enough pimped out phase rigs and ultra tidy high performance WC rigs.
I don't do lan parties anymore so I have no need to build show class machines.
I had a bucketload of bits lying around going to waste.
Took an old big Inwin Q500 tower chassis, hacked it to bits, painted it up. merged 2 dual heatercores together 100% airtight with perfectly matched channels for great airflow through both cores and sealed up all other areas so all the air being pulled has to pass through both cores. Short shrouds are sealed on airtight along with 2 Sharkoon Silent Eagle 2000 fans on fanmates. This then goes to an Apogee, a EK Northbridge cooler and then to an Alphacool Mosfet cooler. This then goes up to the roof into an external Thermochill PA 120.3 rad. From there into a Mcres micro near the top of the case, then to a bay res as I needed to split the flow into 2 barbs and also have the benefit of seeing the coolant. This then goes into a Hardwareluxx dual DDC pump mount with 2 DDC Ultras taking car of the pumping duties in series.
No VGA cooling yeat as I saw no point in shelling out for a block when I will be changing card in a few months. This rig isn't completely finished yet as I am still doing the wiring but so far all the kit is in and working, the PA 120.3 is running passive atm until I fit the fans. Now, with only 2 fans running, the 2 in the 'ubercore' at 1000RPM I have a BIOS core temp report of 20-21C! Coretemp via XP shows both cores on 35-36c
This is a Lapped Core 2 Duo E6700 on a P5WDH and the Apogee is lapped too. When cranked up to a basic 3.3Ghz the BIOS is reporting 23.5-24.5. I haven't run coretemp on this config as it was just a test fireup. I have already had this chip briefly at 3.75Ghz on air and the temps sure weren't as low as what I am getting now
Basically I have written all that guff to say that I didn't follow people's unwanted opinions over this setup telling me on other forums I would kill flowrate etc and make it perform worse, built what I wanted for the hell of it, I have a huge cooling capacity now to add in god know's what in the future and have a damn cool running CPU/chipset/mosfets
. Also visually the flowrate is phenomenal and this is using a mix of 1/2" masterkleer and 3/8" tygon tubing.
In my opinion and experience 2 radiators are better than one when the right setup is specced and implemented properly
