Hi.
I had a system setup where I had 2 routers:
1) broadband router which also had wireless
2) another wireless router which is better than the broadband router and gave me better wireless in addition to features.
its been a while since I set it up.
now I have temporarily moved due to personal circumstances.
I have a Cisco E4200 router (which is #2 above). I also have a virgin media broadband router which is a netgear I believe. IT is rubbish.
how can I wire them up so the DHCP for internal is given by my wireless router and the virgin media DHCP is switched off?
I would like both wirelesses to work if possible and allow me to choose whichever one I want for it to work.
I will be connecting the cisco wireless router to my netgear powerline adapter and the main computer to the cisco router also.
what would be even better, but probably not possible, is if I can have both routers give out DHCP internally but whichever computer is wired (or wirelessly) to either router, it will give out its DHCP IP address locally but still be able to access the internet without issues.
thank you.
thank you.
