Question 1
Ok currently I have a GTX 670 and am currently trying to decided on if worth upgrading 2 a new single gpu or to go SLI. Is it worth ging SLI or should I just try and save for a new single card. The 670 basicly eats everything I throw at it most of the time unless I play something like skyrim heavily modded then it showing its age.
Question 2
I have the Gigabyte 670 2gb with 980MHz core. Generally I know most GPU can be SLI as long as the same card and ram amount but with the gigabyte having a slightly higher clock speed than the standard would I have to get another Gigabyte one or could I get away with say using an msi that has a 965MHz Core?
Question 2
