- 16 Nov 2010
- Swimming in a lake
Right, So I am looking for the quietest 2 slot GPU cooler around.
The original plan was to purchase a Phantom, and rely on a slight overhang off the bottom of the motherboard. Problem is, I've double checked, and it looks like the gap between the bottom PCI slot on the case and the PSU is basically 5mm max. From what I've read the Phantom cooler is more 2.5 slots, so this wouldn't work.
I'll probably get the 670 version of whatever card I go with as a reference.
The reason that the GPU has to go where it is is that basically the mATX boards, to allow for SLI, put the 4 slots as:
PCI-Ex16
PCI-Ex1
PCI-Ex16
PCI-Ex16
And there's no way I'm loosing my sound card, so I need the PCI x1 slot... Hence yeah, the dilemma...
The final option I guess, is to hope that they release a very quiet reference cooler on the 670... Something like the stock 560 cooler wouldn't go amiss I guess...
kd
PCI-Ex16
PCI-Ex1
PCI-Ex16
PCI-Ex16
kd
