2 super quiet 80mm fans, that can push serious air?? suggestions plz
1 May 2006
UK
hi guys i need 2 80mm fans to replace my akasa 80mms in the back of my enermax CS-527. would like something with blue leds....but i need these fans too be real quiet at 5-7V and pretty quiet at 12V...cheers guys
The best 80mm fans for cfm/dB ratio is probably the Akasa ambers. Unfortunatly these arnt LED, but you could always buy a Cathode if you need a bit of light
SilenX do 80mm led fans, which are quiet but don't shift that much air. Or AC Ryan but I heard their build quality is abit shabby?
I heard that the best case fans were the PAPST ones. Although a little tricky to find, you cant get better. When I get some myself I will let you know ;)
My 2x 80mm Panaflows are silent at 12v, and still push some decent airflow.
No LEDs, I'm afraid.
You're asking the impossible... High air flow = higher noise... Instead you need to find a compromise.
Not sure which Akasa fans you have, but Thunderblades are pretty quiet (@ 5/7v), and still give off some light.
Also, from my experience, the fan at the back of the case (near the CPU) is the most important for CPU temp.
