Hi all, please be gentle, out of my depth here!
I have the VM Superhub and whilst speed is good range is shocking!
For some reason Virgin sent 2 Superhubs to me when I ordered it so I want to know if I can connect both to extend the network.
I have connected together via Ethernet cable and the following happens -
The 1st hub still works fine
I can connect to the 2nd hub and this also works fine.
When I reconnect to the 1st hub I get no Internet connection.
Tried this several times with the same result.
Can anyone help? Ideally I would like to use the same network name to avoid having to connect to different networks. Is this possible ?
Thanks for reading
Steve
Thanks for reading
Steve
