hey guys,
I currently have a wireless keyboard that runs on 2.4GHz and I'm thinking of getting a AV signal sender so I can watch my HTPC on my TV in my room but all the ones I can find run on the same frequency.
What would happen if I had two devices running at the same time on the same frequency??
The AV sender has 4 channel options and the keyboard has none. Would changing the channel of the AV sender make any difference.
I could buy a AV sender that using 5.4GHz but they are expensive and I'm trying to do this on a very tight budget.
Help, anyone??
Cheers in advance.
Help, anyone??
Cheers in advance.
