Sry about the crap pic.
It drops the furmark temps from 94 to 84 deg.
Got to say, it was prolly more fun making it than it is useful. I took out the card blank at the back of the case (between the cards) and put and exhaust grated one in just incase you are wondering if all I made was a pressure box.
The cards run around 4 deg cooler at idle> My main problem though was the top card got a lot hotter than the bottom, due to heat being radiated from the back of the bottom one (burny hot). It has at least fixed this problem.
I'm going to lift it up abot 20 - 30mm to see if it works any better.
Or maybe mod it more if anyone has any ideas?
