As the title says.
Is it worth it if the 7950s are clocked to 7970 speeds?
Really not bothered about noise.
I just wanted to know if they perform roughly the same when clocked to 7970 speeds and above.
At reference speeds 2 x 7950s manage over 100fps in BF3 at 1200p with 4xAA. If overclocked to 7970 speeds you'd be looking at closer to 120fps.
Fair enough, though the review here shows the same 100fps+ result (at 1080p) and shows what settings they used. It's possible Guru3D used a more demanding timedemo.And where does it say what setting they're using apart from 4xAA?
The Guru3D review here gives an average of 75FPS @1200p and we know what settings they used
Our Battlefield 3 DirectX 11 benchmark run, here we are in DX11 mode with Ultra settings. This is the Operation Swordbreaker level where there is a good balance in-between graphics card GPU load and processor utilization, making this an excellent level to test GPU performance in. There will be levels that are a tiny bit more stringent, there will be levels and sections way more easy. We think this level is the best representation of the game engine though.
