2 x PoE Devices, One Cable With a RJ45 Splitter
16 Dec 2003
Halifax , UK
We have a long run of Cat5e from a PoE switch at one end to an IP camera at the other.
The customer wants to add another camera next to the existing one so my question is would the following setup work:
PoE Switch ---------Cat 5e---------> RJ45 Splitter----> 2 x IP Cameras
The PoE switch supports up to 53w, each camera draws 5w. With the above setup he'd have a total of 5 cameras, therefore 25w.
Any thoughts? :D
There are PoE standards (e.g. 802.3af), and also different modes for the power (phantom vs spare pairs). There are also non-standard implementations.
You need to know what you're using.
That PoE switch appears to only support 802.3af mode B (it uses the spare pairs for power). To have any chance you'd need injectors that support mode A (phantom power).
As already mentioned it makes more sense to run another cable.
The majority of cheaper PoE requires all 4 pairs of copper within the Cat5e cable, therefore a splitter will not give you sufficient pairs to carry both power and data to two cameras.
