2 XBOX 360s and one subscription ?
20 Aug 2006
I currently have one - connected to my PC monitor (Dell 24 inch TFT) and have gold sub - I'll play 70% of my games on this one
what I'd like is another for the living room - for media centre playback + games on a big screen _ surround sound
I'd have one in the lounge all the time, but access to the TV with other family members is not always that easy !
so if I have the 2 360s - can I still just use the one account ? As long as only one 360 is on at any time ?
2ndly - presumably all gamesaves are on the host HDD - so say playing single player COD4 - on say XBOX 1, if I then play it on XBOX2 it'll have no idea of my progress ?
presumably this won't cause any problems other than being annoying ?
thanks, Mark.
:) - thanks
its a pity really as the 360 no. 1 is only about 25m (cable distance wise) from the larger Plasma in the living room - but getting
(1) splitting sound and video into 2
(2) then getting the VGA+ Optical 25m
is quite a problem :(
I've got a similar set up with a second in my bedroom for Media centre duties. I've found the easiest method to share an account is to just pop the hard drive out and use it in the second 360..no messing around with copying profiles on to memory cards.
This will work especially well if you'll just be using one at a time.
