2 Xboxes 1 router
24 Jan 2009
Edinburgh
I have an Xbox in my room
My Bro has one in his room
We have the Virgin Media 'Superhub' and we can both play online when it comes to Forza 3. However when we try to play zombies online (with other people) It doesn't seem to work. He gets put into 1 lobby and i get put into a different one. Anyone have idea's on how to fix this?
It works when its just us 2 doing a private lobby though.
The Game is Black Ops by the way.
Any ideas?
Cant see why it doesnt work , i have 2 xbox consoles online at the same time with no probs .
Could be the poor router that you have .
I'd say NAT Types. You'll need to open, not strict or moderate.
Look into port forwarding Xbox Live if you haven't already. You'll need to open the ports up on your router.
You can't forward ports to both xboxes though so save someone unnecessarily posting instructions, let us know what your NAT types are and if either of them are moderate or strict, post the model of your router too.
I thought you'd both have to join the same party or your treat as 2 seperate people. I know when I've got 2 ps3's on, if they don't join the party then it'll stick you in random lobbys. And this is with one ps3 open and other moderate nat types.
always had issues with 2 xboxes on my old network. had VM internet and a WRT54GL with tomato installed.
They would both connect to Live ok at the same time but depending on which was turned on first, the other wouldn't be able to use voice chat and would have issues joining games. I had ports setup as well as a DMZ etc but never got it working right :(
This issue has been around for a while. There was a new firmware release reletivly recently that should have solved this problem firmware r10. This solved my problem. On top of this you can try making sure plug and play is enabled on the router and set one of the xboxes to auto ip and put a static ip on the other one then forward the ports for the static ip through the router.
I seem to remember trying this and never being able to get open NAT types on both xboxes at the same time. Whichever was turned on first would get the open NAT and the other would get moderate.
