- 12 Feb 2006
- Surrey
sos about title not realy sure what best to describe it.
basicllay i got 2 monitors, a 20" and a 19" both from viewsonic.
The 20" resolution is 1680x1050 and 19" is 1280x1024 which is the highest i can set for both.
now thats seems fine but the thing is the pixels per inch is not correct as the 19" shows windows bigger then the 20" and i would have thought they are supposed to be the same?
is there any way to fix this so they show same pixels per inch as each other?
