20 inch tft or 22 ?
27 Jan 2005
Letchworth Herts uk
Hi All i,m looking at getting a new tft Monitor ,i know the make that i want to get is 'Viewsonic' but after looking at the dimentions of the 20 inch & 22 inch ,there doesn,t seem to be a lot of size difference ,is this true ? :confused:
Dimensions (WxDxH): 48.5 cm x 20.1 cm x 44.1 cm
Dimensions (WxDxH): 52.4 cm x 24.4 cm x 48.2 cm
Those look like dimensions for the monitor, including bezel, not just the screen.
ok this is off the viewsonic website :
DIMENSIONS 20 inch
(WxHxD) Physical (mm) 485mm x 441mm x 201mm (with stand)
485mm x 340mm x 67mm (without stand)
Physical (in.) 19.0" x 17.3" x 7.9" (with stand)
19.0" x 13.4" x 2.6" (without stand)
DIMENSIONS 22 inch
DIMENSIONS
(WxHxD) Physcial (mm) 524mm x 482mm x 244mm (with stand)
(W x H x D) 524mm x 388mm x 58mm (without stand)
Physical (in.) 20.6" x 19" x 9.6" (with stand)
20.6" x 15.3" x 2.3" (without stand)
