Basically ive finally got enough money to buy a monitor so i can get off this old 17 inch 4:3 samsung. Choice is between Samsung 226bw and Dell 2007wfp.
Sammy 226bw: Looks nice, newer and has the two extra inches over the Dell. A bit worried bout the whole TN panel colour shift thing, Blue LED power light being annoying and bleeding into the panel and the shiny bezel reflecting stuff and getting annoying.
Dell2007wfp, but A03 revision: Looks nice and should have better height adjustment, has a better panel, and more connections. A bit worried that its not A04 revision, and most importantly im losing 2 inches of visual space although the resolution is the same.
I have some questions that would help me decide:
1. What is the Dell panel and is it that much better over TN considering I watch quite a lot of movies.
Edit: Found out about the PVA & S-IPS lottery
2. What is the difference between A03 and A04 revisions of the dell?
3. Will I really miss the 2 inches even though the resolutions are the same? (considering i have 17" now). I've been on TV calculator and seen the actual difference but I cannot decide how much effect it has.
Edit: 4. Solved
5. Any other monitors I should consider for the 240 notes range?
Thanks in Advance, Sukh
Edit: 4. Solved
and im not sure that my X1800XT will cope with 22" and the dell does 1:1 pixel mapping which makes life easier
I think the Dell is probably the best screen for the money anyway, still cannot get over the feeling i should be going for the bigger screen even though i would be sacrificing quality
and most people watch TV/DVD on their computers, well at uni they do at least.
