20" or 22"
thats such an open question...
whats better cheese or bread?
by better do u mean advertised response time? if so then yes 2ms is better than 5ms.
what monitor is actually better requries a little more research
Don't have a clue about the monitors in question but the monitors will run at the same resolution so the only thing to gain by kicking it up to 22" is a bit more screen size, so good for watching movies etc. If you're just sitting in front of screen playing games/posting on OCUK forum then 20" might be preferable for you. As I say though, I'm not comparing the particular monitors, just generally comparing 20" and 22".
