- 12 May 2005
I am looking at the phillips widescreen or the Viewsonic one. I was tempted by the very low price of the 19" acer widescreen, but 1440x900 is to low a res after being used to 1600x1200 on a CRT...
Basically, I just wanted to know which one had the better feature set? Can you manually chose the aspect ration on both of them (IE, full screen, leterbox, 4x3) or not? I think you can on the phillips, but could someone confirm this?
Is a DVI cable supplied with these monitors, and how easy is it to switch between inputs, as was going to use it for my 360 also.
Thanks in advance all
